TwinTurbo.NET: Nissan 300ZX forum - Should be able to
Should be able to
Stadsport (PHX)
on August 13, 2012 at 5:28 PM
technical 16 bit ECU question
posted by Dane (Houston)
on August 12, 2012 at 07:08 PM
Depending on what kind of daughterboard it is. I have no experience with JWT socketed 16 bit ECUs, but I personally use a Moates 2-chip adapter board. You write a 16bit (64k) ROM to both chips identically; the board should work with both TT and NA.
Dane (Houston)
19:08:36 08/12/12
Only if she's over 18 (n/m)
Krazyd27(Houston)
21:25:33 08/12/12
Re: technical 16 bit ECU question
Medallion Man
04:15:37 08/13/12
i had assumed the JWT daughter from the TT held my
Dane (Houston)
21:18:59 08/13/12
Should be able to -
Stadsport (PHX)
17:28:39 08/13/12
Yes but you will need to remove and set a jumper
DVDBURN (MD)
21:03:41 08/14/12
